Stop-SdVolumeCloneSplit
Stops your clone volume splitting operation.
Syntax
Stop-SdVolumeCloneSplit [-JobId] <String[]> [-StorageSystem] <String> [-Session] <String> [-Host] <String> [-JobId] <String[]> [-Path] <Object[]> [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
JobId |
false |
true (ByPropertyName) |
StorageSystem |
true |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Path |
Specifies the path to the clone volume you want to stop splitting. |
true |
