SnapCenter 4.7 cmdlets
Stop-SdVolumeCloneSplit
Stops your clone volume splitting operation.
Syntax
Stop-SdVolumeCloneSplit [-JobId]  <String[]>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>  [-JobId]  <String[]>  [-Path]  <Object[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
JobId
false
true (ByPropertyName)
StorageSystem
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Path
Specifies the path to the clone volume you want to stop splitting.
true
