Set-SmCloneJob
Modifies an existing clone job.
Syntax
Set-SmCloneJob [-CloneJobName] <String> [-PluginCode] <PluginCode> [-CloneToInstance] <String> [-CloneToHost] <String> [-Description] <String> [-ResourceGroupName] <String> [-Resources] <Hashtable[]> [-EnableAsupOnFailure] <Boolean> [-EnableSysLog] <Boolean> [-EnableEmail] <> [-EmailPreference] <SmEmailNotificationPreference>
Detailed Description
Modifies an existing clone job based on the parameters provided.
| Name | Description | Required? | Pipeline Input | Default Value |
CloneJobName |
true |
true (ByPropertyName) |
PluginCode |
true |
CloneToInstance |
true |
CloneToHost |
true |
Description |
false |
ResourceGroupName |
false |
Resources |
false |
EnableAsupOnFailure |
false |
EnableSysLog |
false |
EnableEmail |
false |
false |
EmailPreference |
false |
false |
AutoAssignMountPoint |
false |
AssignMountPointUnderPath |
false |
CloneType |
false |
Suffix |
false |
ArchivedLocators |
false |
CustomSnapShotFomat |
false |
CustomText |
false |
SchedulerCredentialName |
false |
Schedules |
false |
SchedulerType |
false |
SchedulerInstance |
false |
DeleteCloneOnScheduleExpiry |
false |
PreScriptCommand |
false |
PreScriptArguments |
false |
PostScriptCommand |
false |
PostScriptArguments |
false |
ScriptTimeOut |
false |
EmailBody |
false |
EmailFrom |
true |
EmailTo |
true |
EmailSubject |
true |
EnableEmailAttachment |
false |
- Example 1: Modifying a clone job to add a suffix. -
Set-SmCloneJob -ResourceGroupName RG1 -CloneJobName CLMJob -PluginCode SCSQL -CloneToInstance R708202074BV1\SQL2019 -CloneToHost R708202074BV1.hnk2.com -Suffix _clone_001
This example syntax modifies a clone job by adding a new suffix.
Result : SMCoreContracts.SMResult
TotalCount : 0
DisplayCount : 0
Context :
Job : SMCoreContracts.SmJob
Name: Clone life cycle of Resource Group 'CLMJob' with policy 'CLMJob_ClonePolicy'
StartTime : 8/25/2020 6:14:05 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 8
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
- Example 2: Modifying a clone job -
Set-SmCloneJob -ResourceGroupName RG1 -CloneJobName CLMJob -PluginCode SCSQL -CloneToInstance R708202074BV1\SQL2019 -CloneToHost R708202074BV1.hnk2.com -AssignMountPointUnderPath 'C:\work' -Suffix _clone_001
This example syntax modifies a clone job.
TotalCount : 0
DisplayCount : 0
Context :
StartTime : 8/25/2020 6:17:34 AM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 8
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
