SnapCenter 4.7 cmdlets
Set-SmCloneJob
Modifies an existing clone job.
Syntax
Set-SmCloneJob [-CloneJobName]  <String>  [-PluginCode]  <PluginCode>  [-CloneToInstance]  <String>  [-CloneToHost]  <String>  [-Description]  <String>  [-ResourceGroupName]  <String>  [-Resources]  <Hashtable[]>  [-EnableAsupOnFailure]  <Boolean>  [-EnableSysLog]  <Boolean>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>
Detailed Description
Modifies an existing clone job based on the parameters provided.
Name Description Required? Pipeline Input Default Value
CloneJobName
true
true (ByPropertyName)
PluginCode
true
CloneToInstance
true
CloneToHost
true
false
ResourceGroupName
false
Resources
false
EnableAsupOnFailure
false
EnableSysLog
false
EnableEmail
false
false
EmailPreference
false
false
AutoAssignMountPoint
false
AssignMountPointUnderPath
false
CloneType
false
Suffix
false
ArchivedLocators
false
CustomSnapShotFomat
false
CustomText
false
SchedulerCredentialName
false
Schedules
false
SchedulerType
false
SchedulerInstance
false
DeleteCloneOnScheduleExpiry
false
PreScriptCommand
false
PreScriptArguments
false
PostScriptCommand
false
PostScriptArguments
false
ScriptTimeOut
false
EmailBody
false
EmailFrom
true
EmailTo
true
EmailSubject
true
EnableEmailAttachment
false
- Example 1: Modifying a clone job to add a suffix. -
 Set-SmCloneJob -ResourceGroupName RG1 -CloneJobName CLMJob -PluginCode SCSQL -CloneToInstance   R708202074BV1\SQL2019 -CloneToHost R708202074BV1.hnk2.com -Suffix _clone_001
This example syntax modifies a clone job by adding a new suffix.
Result   : SMCoreContracts.SMResult
TotalCount   : 0
DisplayCount : 0
Context  :
Job  : SMCoreContracts.SmJob
Name: Clone life cycle of Resource Group 'CLMJob' with policy 'CLMJob_ClonePolicy'
StartTime   : 8/25/2020 6:14:05 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 8
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
- Example 2: Modifying a clone job -
 R708202074BV1\SQL2019 -CloneToHost R708202074BV1.hnk2.com -AssignMountPointUnderPath 'C:\work' -Suffix  _clone_001
This example syntax modifies a clone job.
TotalCount   : 0
DisplayCount : 0
Context  :
StartTime   : 8/25/2020 6:17:34 AM
EndTime :
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 8
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
