SnapCenter 4.9 cmdlets
Get-SmStorageConnection
Retrieves all storage system connections.
Syntax
Get-SmStorageConnection [-Storage]  <String>  [-StorageType]  <String>  [-AzureNetAppAccountId]  <bigint(20)>
Detailed Description
Retrieves information about available storage system connections. You can get information about a specified storage system, or about all of them.
Name Description Required? Pipeline Input Default Value
Storage
false
true (ByPropertyName)
StorageType
Specifies storage type. Valid values are DataOntap and AzureNetAppAccount.
false
Specifies Azure NetApp Account ID.
false
Example 1: Getting storage system connections for a specified storage system
 Get-SmStorageConnection -SVM 172.17.168.13
This example syntax retrieves information for a specified storage system connection.
UserName: vsadmin
Password:
Port: 80
TransportType   : Http
ModifyTime  : 1/1/0001 12:00:00 AM
Mode:
OntapiMajorVersion  :
OntapiMinorVersion  :
Version : NetApp Release 8.2.2X33 Cluster-Mode: Fri Aug 22 06:04:17 PDT 2014
StorageSystemOSType : DataOntap
Passphrase  :
Timeout : 60
Uuid:
OperationContext:
PreferredIpAddress  :
Aliases : {}
SmIPAddresses   : {SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress,
SMCoreContracts.SmIPAddress...}
IPAddresses : {172.17.168.13, 172.17.168.13, 172.17.168.13, 172.17.168.13...}
IsResolved  : True
IsValid : True
Identity: mva-dev-3270-02-d1.lab.netapp.com
Example 2: Getting storage system connections for all available storage systems
This example syntax gets information about all available storage system connections.
UserName: vsadmin
Password:
Port: 80
Mode:
Version :
Passphrase  :
Timeout : 60
Uuid:
OperationContext:
Aliases : {}
IPAddresses : {172.17.124.165, 172.17.124.165, 172.17.124.165, 172.17.124.165...}
IsResolved  : True
IsValid : True
Identity: neeraj_vs1
UserName: vsadmin
Password:
Port: 80
Mode:
Version :
Passphrase  :
Timeout :
Uuid:
OperationContext:
Aliases : {}
IPAddresses : {10.225.13.49, 10.225.13.49, 10.225.13.49, 10.225.13.49...}
IsResolved  : True
IsValid : True
Identity: rtp-rr1-d2.gdl.mycompany.com
Example 3: Getting Azure NetApp Account with specified ID
 Get-SmStorageConnection -StorageType AzureNetAppAccount -AzureNetAppAccountId 1
This example gets information about Azure NetApp Account with specified ID.
NetAppAccountId   : 9
NetAppAccountName : test
ResourceGroupName : test
StorageOSType : AzureNetAppAccount
CredentialName: test1
CredentialId  : 209
ModifyTime: 3/4/2020 6:45:08 AM
ModifyTimeTicks   : 637189011080000000
StorageBaseId : 211
