Get-SmStorageConnection
Retrieves all storage system connections.
Syntax
Get-SmStorageConnection [-Storage] <String> [-StorageType] <String> [-AzureNetAppAccountId] <bigint(20)>
Detailed Description
Retrieves information about available storage system connections. You can get information about a specified storage system, or about all of them.
Name | Description | Required? | Pipeline Input | Default Value |
Storage |
false |
true (ByPropertyName) |
StorageType |
Specifies storage type. Valid values are DataOntap and AzureNetAppAccount. |
false |
AzureNetAppAccountId |
Specifies Azure NetApp Account ID. |
false |
Example 1: Getting storage system connections for a specified storage system
Get-SmStorageConnection -SVM 172.17.168.13
This example syntax retrieves information for a specified storage system connection.
UserName: vsadmin Password: Port: 80 TransportType : Http ModifyTime : 1/1/0001 12:00:00 AM Mode: OntapiMajorVersion : OntapiMinorVersion : Version : NetApp Release 8.2.2X33 Cluster-Mode: Fri Aug 22 06:04:17 PDT 2014 StorageSystemOSType : DataOntap Passphrase : Id : 5 Timeout : 60 Uuid: OperationContext: PreferredIpAddress : Aliases : {} SmIPAddresses : {SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress...} IPAddresses : {172.17.168.13, 172.17.168.13, 172.17.168.13, 172.17.168.13...} Name: mva-dev-3270-02-d1.lab.netapp.com IsResolved : True IsValid : True Identity: mva-dev-3270-02-d1.lab.netapp.com
Example 2: Getting storage system connections for all available storage systems
This example syntax gets information about all available storage system connections.
UserName: vsadmin Password: Port: 80 TransportType : Http ModifyTime : 1/1/0001 12:00:00 AM Mode: OntapiMajorVersion : OntapiMinorVersion : Version : StorageSystemOSType : Passphrase : Id : 1 Timeout : 60 Uuid: OperationContext: PreferredIpAddress : Aliases : {} SmIPAddresses : {SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress...} IPAddresses : {172.17.124.165, 172.17.124.165, 172.17.124.165, 172.17.124.165...} Name: neeraj_vs1 IsResolved : True IsValid : True Identity: neeraj_vs1 UserName: vsadmin Password: Port: 80 TransportType : Http ModifyTime : 1/1/0001 12:00:00 AM Mode: OntapiMajorVersion : OntapiMinorVersion : Version : StorageSystemOSType : Passphrase : Id : 2 Timeout : Uuid: OperationContext: PreferredIpAddress : Aliases : {} SmIPAddresses : {SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress...} IPAddresses : {10.225.13.49, 10.225.13.49, 10.225.13.49, 10.225.13.49...} Name: rtp-rr1-d2.gdl.mycompany.com IsResolved : True IsValid : True Identity: rtp-rr1-d2.gdl.mycompany.com
Example 3: Getting Azure NetApp Account with specified ID
Get-SmStorageConnection -StorageType AzureNetAppAccount -StorageConnectionId 3
This example gets information about Azure NetApp Account with specified Storage connection Id.
StorageConnectionId : 3 SubscriptionId : 398e471c-3b42-4ae7-9b59-ce5bb5e6108d NetAppAccountName : poojar_SCSHANA_Account ResourceGroupName : poojar StorageOSType : AzureNetAppAccount CredentialName : HCLMain CredentialId: 7 ModifyTime : 10/18/2023 10:15:48 AM ModifyTimeTicks : 638332209480000000 StorageBaseId : 3 Location: eastus2
