SnapCenter 4.9 cmdlets
Add-SmCloneJob
Creates a new clone job.
Syntax
Add-SmCloneJob [-CloneJobName]  <String>  [-PluginCode]  <PluginCode>  [-CloneToInstance]  <String>  [-CloneToHost]  <String>  [-Description]  <String>  [-ResourceGroupName]  <String>  [-Resources]  <Hashtable[]>  [-EnableAsupOnFailure]  <Boolean>  [-EnableSysLog]  <Boolean>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>
Detailed Description
Creates a new clone job for the resource group.You can do the following to the clone job: add resources, define specific schedule policy, attach policies, set notification settings for Event Management System (EMS) logs, AutoSupport, send Email notification, specify clone options including clone type and instance, mount options, attach a suffix to the clone job name. Specify the secondary location if you are cloning to a SnapMirror or SnapVault destination.
Name Description Required? Pipeline Input Default Value
CloneJobName
Specifies the name of the clone job.
true
true (ByPropertyName)
PluginCode
Specifies the plug-in code of the host for which you are creating a clone job. Valid values are SCSQL and SCO.
true
CloneToInstance
Specifies the SQL Server instance that you want to clone to. All databases in the clone resource group are cloned to this instance.
true
CloneToHost
Specifies the host to which you are cloning.
true
Provides an optional description of the clone job you are creating.
false
ResourceGroupName
false
Resources
Specifies the resources you want to add to the clone resource group.You must provide the resource information in a hashtable, and it must contain the resource name and type, as well as the host on which the resource is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}Valid Type values are SQL Database and Oracle Database.You can include comma-separated values for Names.
false
EnableAsupOnFailure
Specifies whether to enable or disable AutoSupport on failure.
false
EnableSysLog
Specifies whether to enable or disable sys log in the storage system.
false
EnableEmail
Specifies whether to enable or disable email notifications.
false
false
EmailPreference
Specifies when you will receive email notifications.Possible values: Always, Never, OnError, OnErrorOrWarning.
false
false
AutoAssignMountPoint
Specifies that the file system mount point is assigned automatically.
false
AssignMountPointUnderPath
Specifies that the file system mount point is created automatically under the specified mount path.
false
CloneType
false
Suffix
Provides a clone job name suffix. The clone job you create is appended with the suffix name.
false
ArchivedLocators
Specifies the secondary storage system details for each of the unique primary storage system resource in the dataset. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"}
false
CustomSnapShotFomat
Specifies the custom Snapshot copy naming format. For example, -CustomSnapShotFomat '$CustomText$ResourceGroup$Policy$HostName' -CustomText NetApp
false
CustomText
Specifies the custom text in the custom Snapshot copy naming format.
false
SchedulerCredentialName
false
Schedules
Specifies in a hastable the schedule for the clone job, including the policy name and the schedule type. For example, -Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}You can specify multiple schedules in a comma-separated list.
false
SchedulerType
Specifies the scheduler type. Possible values are Windows, SQL, and None.
false
SchedulerInstance
false
DeleteCloneOnScheduleExpiry
Specifies that the clone be deleted when the scheduled expiration time is reached.
false
PreScriptCommand
Prescript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names).
false
PreScriptArguments
Specifies the prescript arguments.
false
PostScriptCommand
Postscript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names).
false
PostScriptArguments
Specifies postscript arguments.
false
ScriptTimeOut
Specifies the number of seconds before a script times out. The default is 60 seconds.
false
EmailBody
Specifies the body of the email.
false
EmailFrom
Specifies the sender's email address.
true
EmailTo
Specifies the recipient's email address.
true
EmailSubject
Specifies the subject of the email.
true
EnableEmailAttachment
Specifies whether you are adding an email attachment.
false
Example 1: Adding a new clone job
 Add-SmCloneJob -CloneJobName TestCLM1  -PluginCode SCSQL -CloneToInstance "CsmDevSuman\INST1" -CloneToHost host.example.com -Description 'testing clm'
          -Resources @{"Host"="CsmDevSuman";"Type"="SQL Database";"Names"="CsmDevSuman\INST1\TrialDB"} -Suffix "_Clone_July_12" -AutoAssignMountPoint
Example 2: Creating a clone job with hourly schedule policy
 Add-SmCloneJob -Resources @{"Host"="Cluster50176661";"Type"="SQL Database";"Names"="SQL12050176661\CLUSINST1\Cluster50176661_MDML_4"} -CloneJobName 'CloneJob_08767' -PluginCode 'SCSQL' -CloneToInstance 'SQL12050176661\CLUSINST1' -CloneToHost 'Cluster50176661' -autoassignmountpoint  -suffix '_Clone_08767' -schedulertype 'Windows' -schedules @{"ScheduleType"="Hourly";"StartTime"="05/30/2019 6:00 AM";"EndTime"="05/30/2019 8:57 AM";"RepeatTask_Every_Hour"="01:00"}
Example 3: Creating a clone job with daily schedule policy
 Add-SmCloneJob -Resources @{"Host"="Cluster50176661";"Type"="SQL Database";"Names"="SQL12050176661\CLUSINST1\Cluster50176661_MDSL_4"} -CloneJobName 'CloneJob_00970' -PluginCode 'SCSQL' -CloneToInstance 'SQL12050176661\CLUSINST1' -CloneToHost 'Cluster50176661' -suffix '_Clone_00970' -archivedlocators @{Primary="10.225.85.167:QA12050176661_1_MDSL_Data_Log_Vol";Secondary="C_84_173_CIT_SVM_2:QA12050176661_1_MDSL_Data_Log_Vol_SV"} -schedulertype 'Windows' -assignmountpointunderpath 'D:\MSSQL11.CLUSINST1\MSSQL\DATA\Clone10971' -schedules @{"ScheduleType"="Daily";"StartTime"="05/30/2019 6:25 AM";"EndTime"="05/30/2019 9:22 AM";"daysInterval"="1"} -clonetype 1
Example 4: Creating a clone job with weekly schedule policy
 Add-SmCloneJob -Resources @{"Host"="Cluster50176661";"Type"="SQL Database";"Names"="SQL12050176661\CLUSINST1\Cluster50176661_MDML_4"} -CloneJobName 'CloneJob_54758' -PluginCode 'SCSQL' -CloneToInstance 'SQL12050176661\CLUSINST1' -CloneToHost 'Cluster50176661' -autoassignmountpoint  -suffix '_Clone_54758' -schedulertype 'Windows' -schedules @{"ScheduleType"="Weekly";"StartTime"="05/30/2019 6:30 AM";"EndTime"="05/30/2019 9:27 AM";"DaysOfTheWeek"="Thursday,Saturday"}
Example 5: Creating a clone job with monthly schedule policy
 Add-SmCloneJob -Resources @{"Host"="Cluster50176661";"Type"="SQL Database";"Names"="SQL12050176661\CLUSINST1\Cluster50176661_MDML_4"} -CloneJobName 'CloneJob_02494' -PluginCode 'SCSQL' -CloneToInstance 'SQL12050176661\CLUSINST1' -CloneToHost 'Cluster50176661' -suffix '_Clone_02494' -assignmountpointunderpath 'D:\MSSQL11.CLUSINST1\MSSQL\DATA\Clone10971' -schedulertype 'Windows' -schedules @{"ScheduleType"="Monthly";"StartTime"="05/30/2019 6:40 AM";"EndTime"="05/30/2019 9:37 AM";"MonthsofTheYear"="May,June";"DaysoftheMonth"="30,4,25"}
