Repair-SdAluaPaths
Repairs disks with no active/optimized ALUA paths.
Syntax
Repair-SdAluaPaths [-Paths] <String[]> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Paths |
Specifies the drive letter or mount point of the file system to fix a path. |
false |
true (ByPropertyName) |
Session |
false |
Host |
Specifies the name of the host. |
false |
Example 1: Repairing disks with no optimized ALUA paths
PS C:\> Repair-SdAluaPaths
This example syntax repairs disks with no optimized ALUA paths.
