SnapCenter cmdlets
Repair-SdAluaPaths
Repairs disks with no active/optimized ALUA paths.
Syntax
Repair-SdAluaPaths [-Paths]  <String[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Paths
Specifies the drive letter or mount point of the file system to fix a path.
false
true (ByPropertyName)
Session
false
Host
Specifies the name of the host.
false
Example 1: Repairing disks with no optimized ALUA paths
 PS C:\> Repair-SdAluaPaths
This example syntax repairs disks with no optimized ALUA paths.
