SnapCenter 4.9 cmdlets
Get-SmCertificateSettings
Displays the certificate status for the SnapCenter Server or a SnapCenter plug-in host.
Syntax
Get-SmCertificateSettings [-Server]  <>  [-Host]  <>  [-HostName]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Server
Displays the certificate status for the server on which SnapCenter is installed.
true
false
Host
Displays the certificate status for the Snapcenter host.
true
false
HostName
Specifies the name of the host only when the Host parameter is specified.
true
false
Example 1: Displays certificate settings for server
 Get-SmCertificateSettings -Server
This example syntax displays certificate settings for server.
True
Example 2: Displays certificate settings for Host
 Get-SmCertificateSettings -Host -HostName R71104B320CV1.mva.gdl.englab.netapp.com
This example syntax displays certificate settings for host.
HostName   : R71104B320CV1.mva.gdl.englab.netapp.com
			CAEnabled  : True
			CAStatus   : Connection is broken.
			CAIssues   : Host: R71104B320CV1.mva.gdl.englab.netapp.com. Reason: Trusted chain certificates are missing for the
								 certificate 'R71104B320CV1.mva.gdl.englab.netapp.com'.  Check if intermediate and root CA certificates
								 exist in the trusted root store.
			Name   :
			Type   :
			Id :
			Host   :
			UserName   :
			Passphrase :
			Deleted: False
			Auth   : SMCoreContracts.SmAuth
			IsClone: False
			CloneLevel : 0
			Hosts  : {}
			StorageName:
			ResourceGroupNames :
			PolicyNames:
			Key: 0
			NsmObjectID: 0
			SizeOfSmObject : SMCoreContracts.SmObjectSize
