Get-SmCertificateSettings
Displays the certificate status for the SnapCenter Server or a SnapCenter plug-in host.
Syntax
Get-SmCertificateSettings [-Server] <> [-Host] <> [-HostName] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
Server |
Displays the certificate status for the server on which SnapCenter is installed. |
true |
false |
Host |
Displays the certificate status for the Snapcenter host. |
true |
false |
HostName |
Specifies the name of the host only when the Host parameter is specified. |
true |
false |
Example 1: Displays certificate settings for server
Get-SmCertificateSettings -Server
This example syntax displays certificate settings for server.
True
Example 2: Displays certificate settings for Host
Get-SmCertificateSettings -Host -HostName R71104B320CV1.mva.gdl.englab.netapp.com
This example syntax displays certificate settings for host.
HostName : R71104B320CV1.mva.gdl.englab.netapp.com
CAEnabled : True
CAStatus : Connection is broken.
CAIssues : Host: R71104B320CV1.mva.gdl.englab.netapp.com. Reason: Trusted chain certificates are missing for the
certificate 'R71104B320CV1.mva.gdl.englab.netapp.com'. Check if intermediate and root CA certificates
exist in the trusted root store.
Name :
Type :
Id :
Host :
UserName :
Passphrase :
Deleted: False
Auth : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts : {}
StorageName:
ResourceGroupNames :
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject : SMCoreContracts.SmObjectSize
