SnapCenter 4.9 cmdlets
Set-SmMultiFactorAuthentication
To Enable or disable the MFA feature or to configure the MFA for the SnapCenter GUI, Rest API, PowerShell and sccli.
Syntax
Set-SmMultiFactorAuthentication [-IsGuiMFAEnabled]  <>  [-IsRestApiMFAEnabled ]  <>  [-IsCliMFAEnabled ]  <>  [-Path]  <>  [-Path]  <>  [-IsGuiMFAEnabled]  <>  [-IsRestApiMFAEnabled ]  <>  [-IsCliMFAEnabled ]  <>
Detailed Description
To enable or disable the MFA feature or to configure the MFA for the SnapCenter GUI, Rest API, PowerShell and sccli.
Name Description Required? Pipeline Input Default Value
IsGuiMFAEnabled
Specifies the SnapCenter Server to enable or disable MFA for the SnapCenter GUI.
false
false
IsRestApiMFAEnabled
Specifies the SnapCenter Server to enable or disable MFA for the SnapCenter Rest API.
false
false
IsCliMFAEnabled
Specifies the SnapCenter Server to enable or disable MFA for the SnapCenter PowerShell and sccli.
false
false
Path
Configure the MFA for the SnapCenter Server login with specified AD FS metadata file path.
false
false
Example 1: Enabling MultiFactorAuthentication for GUI, Rest API, PowerShell and sccli
 Set-SmMultiFactorAuthentication -IsGuiMFAEnabled $true -IsRestApiMFAEnabled    $true -IsCliMFAEnabled   $true -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter GUI, Rest API, PowerShell and sccli configured with specified AD FS metadata file path.
IsGuiMFAEnabled = True
ADFSConfigFilePath = C:\\ADFS_metadata\\FederationMetadata.xml
SCConfigFilePath = c:\ProgramData\NetApp\SnapCenter\Package Repository\SnapCenterMFAMetadata.xml
IsRestApiMFAEnabled = True
IsCliMFAEnabled = True
ADFSHostName = adfs19.ad19domain.com
Example 2: Disabling MultiFactorAuthentication for SnapCenter GUI
 Set-SmMultiFactorAuthentication -IsGuiMFAEnabled $false
This example syntax disables MFA for SnapCenter GUI.
IsGuiMFAEnabled = False
ADFSConfigFilePath = null
SCConfigFilePath = null
IsRestApiMFAEnabled = False
IsCliMFAEnabled = False
ADFSHostName = null
Example 3: Enabling MultiFactorAuthentication for Rest API PowerShell and sccli
 Set-SmMultiFactorAuthentication -IsRestApiMFAEnabled    $true -IsCliMFAEnabled   $true -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter Rest API, PowerShell and sccli configured with specified AD FS metadata file path.
Example 4: Enabling MultiFactorAuthentication only for PowerShell and sccli
 Set-SmMultiFactorAuthentication -IsCliMFAEnabled   $true -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter PowerShell and sccli configured with specified AD FS metadata file path.
Example 5: Disabling MultiFactorAuthentication for GUI, Rest API, PowerShell and sccli
 Set-SmMultiFactorAuthentication -IsGuiMFAEnabled $False -IsRestApiMFAEnabled   $False  -IsCliMFAEnabled   $False
This example syntax disables MFA for SnapCenter GUI, Rest API, PowerShell and sccli.
ADFSHostName = null
Example 6: Disabling MultiFactorAuthentication for Only for Rest API
 Set-SmMultiFactorAuthentication -IsRestApiMFAEnabled   $False
This example syntax disables MFA only for SnapCenter Rest API.
Example 7: Update MultiFactorAuthentication configuration
 Set-SmMultiFactorAuthentication -Path C:\data\FederationMetadata.xml
This example syntax updates MFA configuration for SnapCenter configured with specified AD FS metadata file path.
ADFSConfigFilePath = C:\\data\\FederationMetadata.xml
