Set-SmMultiFactorAuthentication
To Enable or disable the MFA feature or to configure the MFA for the SnapCenter Server login.
Syntax
Set-SmMultiFactorAuthentication [-Enable] <> [-Path] <> [-Path] <> [-Disable] <>
Detailed Description
To enable or disable the MFA feature or to configure the MFA for the SnapCenter Server login.
| Name | Description | Required? | Pipeline Input | Default Value |
Enable |
Specifies the SnapCenter Server to enable MFA for the SnapCenter Server login. |
false |
false |
Path |
Configure the MFA for the SnapCenter Server login with specified AD FS metadata file path. |
false |
false |
Disable |
Specifies the SnapCenter Server to disable MFA for the SnapCenter server login. |
false |
false |
Example 1: Enabling MultiFactorAuthentication
Set-SmMultiFactorAuthentication -Enable -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter Server login configured with specified AD FS metadata file path.
ISMFAEnabled = True
ADFSHostName = adfs19.ad19domain.com
ADFSConfigFilePath = C:\\ADFS_metadata\\FederationMetadata.xml
SCConfigFilePath = c:\ProgramData\NetApp\SnapCenter\Package Repository\SnapCenterMFAMetadata.xml
Example 2: Disabling MultiFactorAuthentication
Set-SmMultiFactorAuthentication -Disable
This example syntax disables MFA for SnapCenter Server login.
ISMFAEnabled = False
ADFSHostName =
SCConfigFilePath =
Example 3: Update MultiFactorAuthentication configuration
Set-SmMultiFactorAuthentication -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax updates MFA configuration for SnapCenter Server login configured with specified AD FS metadata file path.
ISMFAEnabled = True
ADFSConfigFilePath = C:\ADFS_metadata\FederationMetadata.xml
SCConfigFilePath =
