SnapCenter cmdlets
Set-SmMultiFactorAuthentication
To Enable or disable the MFA feature or to configure the MFA for the SnapCenter Server login.
Syntax
Set-SmMultiFactorAuthentication [-Enable]  <>  [-Path]  <>  [-Path]  <>  [-Disable]  <>
Detailed Description
To enable or disable the MFA feature or to configure the MFA for the SnapCenter Server login.
Name Description Required? Pipeline Input Default Value
Enable
Specifies the SnapCenter Server to enable MFA for the SnapCenter Server login.
false
false
Path
Configure the MFA for the SnapCenter Server login with specified AD FS metadata file path.
false
false
Disable
Specifies the SnapCenter Server to disable MFA for the SnapCenter server login.
false
false
Example 1: Enabling MultiFactorAuthentication
 Set-SmMultiFactorAuthentication -Enable -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax enables MFA for SnapCenter Server login configured with specified AD FS metadata file path.
ISMFAEnabled = True
ADFSHostName = adfs19.ad19domain.com
ADFSConfigFilePath = C:\\ADFS_metadata\\FederationMetadata.xml
SCConfigFilePath = c:\ProgramData\NetApp\SnapCenter\Package Repository\SnapCenterMFAMetadata.xml
Example 2: Disabling MultiFactorAuthentication
 Set-SmMultiFactorAuthentication -Disable
This example syntax disables MFA for SnapCenter Server login.
ISMFAEnabled = False
ADFSHostName =
SCConfigFilePath =
Example 3: Update MultiFactorAuthentication configuration
 Set-SmMultiFactorAuthentication -Path C:\ADFS_metadata\FederationMetadata.xml
This example syntax updates MFA configuration for SnapCenter Server login configured with specified AD FS metadata file path.
ISMFAEnabled = True
ADFSConfigFilePath = C:\ADFS_metadata\FederationMetadata.xml
SCConfigFilePath =
