Get-SmResourceCredentialName
Gets credential information of the SQL instance that are registered with the SnapCenter Server.
Syntax
Get-SmResourceCredentialName [-HostName] <String> [-ResourceName] <String> [-ResourceId] <String>
Detailed Description
Gets and displays the credential information of the SQL instance that are registered with the SnapCenter Server.
| Name | Description | Required? | Pipeline Input | Default Value |
HostName |
false |
true (ByPropertyName) |
ResourceName |
false |
ResourceId |
false |
- Example : Get the credential information of the SQL instance by the resource name. -
Get-SmResourceCredentialName -ResourceName R708202074BV1\SQL2019
This example syntax retrieves the credential information of the SQL instance based on the resource name.
Type : SQL Instance
Host : R708202074BV1.HNK2.com
UserName :
Passphrase :
Deleted: False
Auth : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts : {}
StorageName:
ResourceGroupNames :
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject : SMCoreContracts.SmObjectSize
RunAsName : Hnkn
AuthMode : Windows
UserName : HNK2\administrator
Passpharse :
OwnerId:
HostName :
InstanceName :
CheckforAdministratorPrivilage : False
TargetURL :
IsSudoEnabled : False
