Get-SmResourceCredentialName
Gets credential information of the SQL instance that are registered with the SnapCenter Server.
Syntax
Get-SmResourceCredentialName [-HostName] <String> [-ResourceName] <String> [-ResourceId] <String>
Detailed Description
Gets and displays the credential information of the SQL instance that are registered with the SnapCenter Server.
Name | Description | Required? | Pipeline Input | Default Value |
HostName |
false |
true (ByPropertyName) |
ResourceName |
false |
ResourceId |
false |
- Example : Get the credential information of the SQL instance by the resource name. -
Get-SmResourceCredentialName -ResourceName R708202074BV1\SQL2019
This example syntax retrieves the credential information of the SQL instance based on the resource name.
Name : R708202074BV1\SQL2019 Type : SQL Instance Id : 20 Host : R708202074BV1.HNK2.com UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 Hosts : {} StorageName: ResourceGroupNames : PolicyNames: Key: 0 NsmObjectID: 0 SizeOfSmObject : SMCoreContracts.SmObjectSize Id : 3 RunAsName : Hnkn AuthMode : Windows UserName : HNK2\administrator Passpharse : OwnerId: HostName : InstanceName : CheckforAdministratorPrivilage : False TargetURL : IsSudoEnabled : False
