SnapCenter 5.0 cmdlets
Get-SmResourceCredentialName
Gets credential information of the SQL instance that are registered with the SnapCenter Server.
Syntax
Get-SmResourceCredentialName [-HostName]  <String>  [-ResourceName]  <String>  [-ResourceId]  <String>
Detailed Description
Gets and displays the credential information of the SQL instance that are registered with the SnapCenter Server.
Name Description Required? Pipeline Input Default Value
HostName
false
true (ByPropertyName)
ResourceName
false
ResourceId
false
- Example : Get the credential information of the SQL instance by the resource name. -
 Get-SmResourceCredentialName -ResourceName R708202074BV1\SQL2019
This example syntax retrieves the credential information of the SQL instance based on the resource name.
Type   : SQL Instance
Host   : R708202074BV1.HNK2.com
UserName   :
Passphrase :
Deleted: False
Auth   : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts  : {}
StorageName:
ResourceGroupNames :
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject : SMCoreContracts.SmObjectSize
RunAsName  : Hnkn
AuthMode   : Windows
UserName   : HNK2\administrator
Passpharse :
OwnerId:
HostName   :
InstanceName   :
CheckforAdministratorPrivilage : False
TargetURL  :
IsSudoEnabled  : False
