Remove-SmServer
Removes the SC server from the High Availability cluster.
Syntax
Remove-SmServer [-Credential] <PSCredential> [-ServerNameString] <String> [-ServerIPString] <String>
Detailed Description
Removes the given SC server from the High Availability cluster. The SC server should be removed from the load balancing configuration and, SnapCenter should be uninstalled on the server to be removed.
| Name | Description | Required? | Pipeline Input | Default Value |
Credential |
Provides domain user credentials for the user to remove High Availability cluster configuration. |
true |
true (ByPropertyName) |
ServerName |
Secondary SC server name. |
false |
false |
ServerIP |
Secondary SC server IP Address. |
true |
false |
Example 1: Removing SnapCenter Server from High Availability cluster
Remove-SmServer -Credential sddev\administrator -ServerIP 10.225.231.178 -ServerName SecondServer.domain.com
This example removes SnapCenter Server from High Availability cluster.
Remove-SmServer -ServerIP 10.225.231.178
WARNING: Uninstallation of SnapCenter Server on secondary node is recommended.
Name: Removing SnapCenter Server 10.225.231.178 from High Availability Cluster
StartTime : 9/25/2019 1:23:11 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 100
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
