SnapCenter 5.0 cmdlets
Remove-SmServer
Removes the SC server from the High Availability cluster.
Syntax
Remove-SmServer [-Credential]  <PSCredential>  [-ServerNameString]  <String>  [-ServerIPString]  <String>
Detailed Description
Removes the given SC server from the High Availability cluster. The SC server should be removed from the load balancing configuration and, SnapCenter should be uninstalled on the server to be removed.
Name Description Required? Pipeline Input Default Value
Credential
Provides domain user credentials for the user to remove High Availability cluster configuration.
true
true (ByPropertyName)
ServerName
Secondary SC server name.
false
false
ServerIP
Secondary SC server IP Address.
true
false
Example 1: Removing SnapCenter Server from High Availability cluster
 Remove-SmServer -Credential sddev\administrator -ServerIP 10.225.231.178 -ServerName SecondServer.domain.com
This example removes SnapCenter Server from High Availability cluster.
Remove-SmServer -ServerIP 10.225.231.178
WARNING: Uninstallation of SnapCenter Server on secondary node is recommended.
Name: Removing SnapCenter Server 10.225.231.178 from High Availability Cluster
StartTime   : 9/25/2019 1:23:11 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 100
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
