SnapCenter 4.7 cmdlets
Remove-SmResourceFromUser
Removes a SnapCenter resource assigned to specified user.
Syntax
Remove-SmResourceFromUser [-UserName]  <String>  [-ResourceNames]  <String>  [-ResourceType]  <OperationAssignmentType>  [-UserGroupObjectType]  <SmUserGroupObjectType>
Detailed Description
Remove a SnapCenter resource assigned to specified user.
Name Description Required? Pipeline Input Default Value
UserName
Name of the domain\user.
true
true (ByPropertyName)
ResourceNames
Name of the resources to be removed. Allow comma seperated resources names.The resource name is the policy name, resource group name, storage connection name, credential name, host name or IP address, or plug-in name created by the user.
true
ResourceType
Type of resource. The SnapCenter resource types are Credential, Host, ResourceGroup, Policy, StorageConnection or Plugin.
true
UserGroupObjectType
Specifies the user type whose resources are removed. Possible values are User or Group.
false
Example 1: Removing a specific resource from a user
 Remove-SmResourceFromUser -ResourceNames PayrollDataset -ResourceType ResourceGroup -UserName mva\administrator
This example syntax removes the specified resource name from the user indicated.
Are you sure want to perform this action?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):y
Example 2: Removing a specific resource from a user without confirmation dialogue
 Remove-SmResourceFromUser -ResourceNames PayrollDataset -ResourceType ResourceGroup -UserName mva\administrator -Confirm:$false
Example 3: Removing a specific resource from a group.
 Remove-SmResourceFromUser -ResourceNames PayrollDataset -ResourceType ResourceGroup -UserName mva\group1 -UserGroupObjectType Group
This example syntax removes the specified resource name from the identified group.
