Remove-SmResourceFromUser
Removes a SnapCenter resource assigned to specified user.
Syntax
Remove-SmResourceFromUser [-UserName] <String> [-ResourceNames] <String> [-ResourceType] <OperationAssignmentType> [-UserGroupObjectType] <SmUserGroupObjectType>
Detailed Description
Remove a SnapCenter resource assigned to specified user.
| Name | Description | Required? | Pipeline Input | Default Value |
UserName |
Name of the domain\user. |
true |
true (ByPropertyName) |
ResourceNames |
Name of the resources to be removed. Allow comma seperated resources names.The resource name is the policy name, resource group name, storage connection name, credential name, host name or IP address, or plug-in name created by the user. |
true |
ResourceType |
Type of resource. The SnapCenter resource types are Credential, Host, ResourceGroup, Policy, StorageConnection or Plugin. |
true |
UserGroupObjectType |
Specifies the user type whose resources are removed. Possible values are User or Group. |
false |
Example 1: Removing a specific resource from a user
Remove-SmResourceFromUser -ResourceNames PayrollDataset -ResourceType ResourceGroup -UserName mva\administrator
This example syntax removes the specified resource name from the user indicated.
Are you sure want to perform this action?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):y
Example 2: Removing a specific resource from a user without confirmation dialogue
Remove-SmResourceFromUser -ResourceNames PayrollDataset -ResourceType ResourceGroup -UserName mva\administrator -Confirm:$false
Example 3: Removing a specific resource from a group.
Remove-SmResourceFromUser -ResourceNames PayrollDataset -ResourceType ResourceGroup -UserName mva\group1 -UserGroupObjectType Group
This example syntax removes the specified resource name from the identified group.
