SnapCenter 4.7 cmdlets
Restore-SmRepositoryBackup
Restores the SnapCenter database.
Syntax
Restore-SmRepositoryBackup [-HostName]  <String>  [-SMSbaseUrl]  <String>  [-BackupPath]  <String>  [-BackupName]  <String>  [-RestoreFileSystem]  <>
Detailed Description
Name Description Required? Pipeline Input Default Value
HostName
Specifies the SnapCenter database host name. If the SnapCenter database is hosted by a failover cluster instance (FCI), then specify the FCI owner host name.
true
true (ByPropertyName)
SMSbaseUrl
Specifies the SnapCenter Server URL. This URL is required when you are executing the PowerShell command from a database host.
false
BackupPath
Specifies the path where the SnapCenter repository is stored.
false
BackupName
Specifies the name of the backup to restore.
true
RestoreFileSystem
Specifies that the file system can be restored when backups are missing.
false
Example 1: Restoring a database backup
 Restore-SmRepositoryBackup -BackupName MYSQL_DS_SC_Repository_mva-x3550-s09_09-15-2016_10.32.00.4445
This example syntax restores the specified database backup.
You can retrieve -BackupName by using Get-smRepositoryBackups.
