Restore-SmRepositoryBackup
Restores the SnapCenter database.
Syntax
Restore-SmRepositoryBackup [-HostName] <String> [-SMSbaseUrl] <String> [-BackupPath] <String> [-BackupName] <String> [-RestoreFileSystem] <>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
HostName |
Specifies the SnapCenter database host name. If the SnapCenter database is hosted by a failover cluster instance (FCI), then specify the FCI owner host name. |
true |
true (ByPropertyName) |
SMSbaseUrl |
Specifies the SnapCenter Server URL. This URL is required when you are executing the PowerShell command from a database host. |
false |
BackupPath |
Specifies the path where the SnapCenter repository is stored. |
false |
BackupName |
Specifies the name of the backup to restore. |
true |
RestoreFileSystem |
Specifies that the file system can be restored when backups are missing. |
false |
Example 1: Restoring a database backup
Restore-SmRepositoryBackup -BackupName MYSQL_DS_SC_Repository_mva-x3550-s09_09-15-2016_10.32.00.4445
This example syntax restores the specified database backup.
You can retrieve -BackupName by using Get-smRepositoryBackups.
