Get-SmCloneReport
Get reports about clone operations based on the options you specify.
Syntax
Get-SmCloneReport [-FromDateTime] <DateTime> [-ToDateTime] <DateTime> [-ResourceGroup] <String> [-Resource] <String> [-Status] <String> [-HostName] <String> [-Plugin] <PluginCode> [-JobId] <Int64>
Detailed Description
Get reports about clone operations based on the options you specify. For any integer value provided for date, value is taken as 1/1/0001 12:00 AM.
| Name | Description | Required? | Pipeline Input | Default Value |
FromDateTime |
Specifies that you want to get clone operations reports for clones run between a specified day and time.This optionsprovides the start date and time.You can specify the date and time using the local date and time format string.For example, "2/5/20158:17AM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone. |
false |
false |
ToDateTime |
Specifies that you want to get clone operations reports for clones run between a specified day and time.This optionprovides the end date and time.You can specify the date and time using the local date and time format string.For example "2/5/20159:56AM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone. |
false |
false |
ResourceGroup |
false |
false |
Resource |
Specifies the resource for which you want clone reports. |
false |
false |
Status |
Specifies that you want information about clone jobs with the specified status.Valid values are: completed, failed, warning, and canceled. |
false |
false |
HostName |
Specifies the name of the host on which the clone resides. |
false |
false |
Plugin |
Specify the plug-in code to generate the report. For custom plug-ins, specify the custom plug-in name for example, hana, mysql. |
false |
false |
JobId |
ID of the clone job for which to get a report. |
true |
false |
Example 1: Getting a clone report for a date range
Get-SmCloneReport -FromDateTime "7/31/2015" -HostName SCSPR0054212005.mycompany.com
This command syntax gets a report for all clones after July 31st, 2015 on the given host.
SmCloneId : 1
SmJobId : 186
StartDateTime : 8/3/2015 2:43:02 PM
EndDateTime : 8/3/2015 2:44:08 PM
Duration: 00:01:06.6760000
Status : Completed
ProtectionGroupName : Draper
SmProtectionGroupId : 4
PolicyName : OnDemand_Clone
SmPolicyId : 4
BackupPolicyName: OnDemand_Full_Log
SmBackupPolicyId: 1
CloneHostName : SCSPR0054212005.mycompany.com
CloneHostId : 4
CloneName : Draper__clone__08-03-2015_14.43.53
SourceResources : {Don, Betty, Bobby, Sally}
ClonedResources : {Don_DRAPER, Betty_DRAPER, Bobby_DRAPER, Sally_DRAPER}
SmJobError :
PluginCode : SCO
PluginName : Oracle Database
PluginDisplayName : Oracle Database
Example 2: Getting a clone report for a clone job
Get-SmCloneReport -JobId 186
This command syntax gets a clone report for the given job ID.
SmCloneId : 1
SmJobId : 186
Status : Completed
SmPolicyId : 4
SmBackupPolicyId: 1
CloneHostId : 4
SmJobError :
PluginCode : SCO
