SnapCenter cmdlets
Get-SmCloneReport
Get reports about clone operations based on the options you specify.
Syntax
Get-SmCloneReport [-FromDateTime]  <DateTime>  [-ToDateTime]  <DateTime>  [-ResourceGroup]  <String>  [-Resource]  <String>  [-Status]  <String>  [-HostName]  <String>  [-Plugin]  <PluginCode>  [-JobId]  <Int64>
Detailed Description
Get reports about clone operations based on the options you specify. For any integer value provided for date, value is taken as 1/1/0001 12:00 AM.
Name Description Required? Pipeline Input Default Value
FromDateTime
Specifies that you want to get clone operations reports for clones run between a specified day and time.This optionsprovides the start date and time.You can specify the date and time using the local date and time format string.For example, "2/5/20158:17AM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone.
false
false
ToDateTime
Specifies that you want to get clone operations reports for clones run between a specified day and time.This optionprovides the end date and time.You can specify the date and time using the local date and time format string.For example "2/5/20159:56AM". If the cmdlet is run from the remote computer, the output will be shown based on the SnapCenter Server time zone.
false
false
ResourceGroup
false
false
Resource
Specifies the resource for which you want clone reports.
false
false
Status
Specifies that you want information about clone jobs with the specified status.Valid values are: completed, failed, warning, and canceled.
false
false
HostName
Specifies the name of the host on which the clone resides.
false
false
Plugin
Specify the plug-in code to generate the report. For custom plug-ins, specify the custom plug-in name for example, hana, mysql.
false
false
JobId
ID of the clone job for which to get a report.
true
false
Example 1: Getting a clone report for a date range
 Get-SmCloneReport -FromDateTime "7/31/2015" -HostName SCSPR0054212005.mycompany.com
This command syntax gets a report for all clones after July 31st, 2015 on the given host.
SmCloneId   : 1
SmJobId : 186
StartDateTime   : 8/3/2015 2:43:02 PM
EndDateTime : 8/3/2015 2:44:08 PM
Duration: 00:01:06.6760000
Status  : Completed
ProtectionGroupName : Draper
SmProtectionGroupId : 4
PolicyName  : OnDemand_Clone
SmPolicyId  : 4
BackupPolicyName: OnDemand_Full_Log
SmBackupPolicyId: 1
CloneHostName   : SCSPR0054212005.mycompany.com
CloneHostId : 4
CloneName   : Draper__clone__08-03-2015_14.43.53
SourceResources : {Don, Betty, Bobby, Sally}
ClonedResources : {Don_DRAPER, Betty_DRAPER, Bobby_DRAPER, Sally_DRAPER}
SmJobError  :
PluginCode  : SCO
PluginName  : Oracle Database
PluginDisplayName   : Oracle Database
Example 2: Getting a clone report for a clone job
 Get-SmCloneReport -JobId 186
This command syntax gets a clone report for the given job ID.
SmCloneId   : 1
SmJobId : 186
Status  : Completed
SmPolicyId  : 4
SmBackupPolicyId: 1
CloneHostId : 4
SmJobError  :
PluginCode  : SCO
