SnapCenter cmdlets
Get-SmCloneJob
Gets information about existing clone jobs.
Syntax
Get-SmCloneJob [-PluginCode]  <PluginCode>  [-ResourceGroupName]  <String>  [-Resource]  <Hashtable[]>
Detailed Description
Gets and displays information about existing clone jobs based on the plug-in code and the resource group.
Name Description Required? Pipeline Input Default Value
PluginCode
true
true (ByPropertyName)
ResourceGroupName
false
false
Resource
false
false
- Example 1: Getting information about the existing clone jobs running at the resource group level. -
 Get-SmCloneJob -ResourceGroupName RG1 -PluginCode SCSQL
This example syntax retrieves information about the existing clone jobs running at the resource group level.
CloneJobName ResourceGroupName ResourceName
CLMJob RG1
- Example 2: Getting information about the existing clone jobs running at the resource level. -
 Get-SmCloneJob -Resource @{"Host"="R708202074BV1.hnk2.com"; "Type"="SQL Database";"Names"="R708202074BV1\SQL2019\MDML_DB1"} -PluginCode SCSQL
This example syntax gets information about the existing clone jobs running at the resource level.
cl2 R708202074BV1\SQL2019\MDML_DB1
