Get-SmCloneJob
Gets information about existing clone jobs.
Syntax
Get-SmCloneJob [-PluginCode] <PluginCode> [-ResourceGroupName] <String> [-Resource] <Hashtable[]>
Detailed Description
Gets and displays information about existing clone jobs based on the plug-in code and the resource group.
| Name | Description | Required? | Pipeline Input | Default Value |
| PluginCode | true | true (ByPropertyName) | ||
| ResourceGroupName | false | false | ||
| Resource | false | false |
- Example 1: Getting information about the existing clone jobs running at the resource group level. -
Get-SmCloneJob -ResourceGroupName RG1 -PluginCode SCSQL
This example syntax retrieves information about the existing clone jobs running at the resource group level.
CloneJobName                            ResourceGroupName                       ResourceName
CLMJob                                  RG1
- Example 2: Getting information about the existing clone jobs running at the resource level. -
 Get-SmCloneJob -Resource @{"Host"="R708202074BV1.hnk2.com"; "Type"="SQL Database";"Names"="R708202074BV1\SQL2019\MDML_DB1"} -PluginCode SCSQL
This example syntax gets information about the existing clone jobs running at the resource level.
cl2        R708202074BV1\SQL2019\MDML_DB1
 PDFs
PDFs
