Set-SmHost
Modifies either the port or the group Managed Service Account (gMSA) or the credential name of the host.
Syntax
Set-SmHost [-HostName] <String> [-Port] <UInt16> [-CredentialName] <String> [-UseGMSA] <Boolean> [-GMSAName] <String> [-PushServerCredentialsToSCV] <SwitchParameter> [-Force] <SwitchParameter>
Detailed Description
Modifies either the port or the group Managed Service Account (gMSA) or the credential name of the host. Only one parameter can be modified at a time.
| Name | Description | Required? | Pipeline Input | Default Value |
HostName |
The name of the host whose port or credential name will be modified. |
true |
true (ByPropertyName) |
Port |
The port to be modified. |
false |
CredentialName |
The credential name to be modified. |
false |
UseGMSA |
Modify the plug-in services logon from gMSA to domain or LocalSystem. |
false |
GMSAName |
The group Managed Service Account (gMSA) name to be modified. |
false |
PushServerCredentialsToSCV |
Push the credentials to the SCV host. |
false |
Force |
false |
Example 1: Modifying port from 8145 to 8185
Set-SmHost -HostName h1 -Port 8185
This example modifies the port of host h1 to 8185.
Example 2: Modifying credential name from RunAs1 to RunAs2
Set-SmHost -HostName h1 -CredentialName RunAs2
This example modifies the credential name of host h1 to RunAs2.
Example 3: Modifying group Managed Service Account (gMSA) name from NewDomain\gMSAName1$ to NewDomain\gMSAName2$
Set-SmHost -HostName h1.NewDomain.com -UseGMSA:$true -GMSAName NewDomain\gMSAName2$
This example modifies the gMSA name for host h1.NewDomain.com to NewDomain\gMSAName2$.
Example 4: Disabling group Managed Service Account (gMSA)
Set-SmHost -HostName h1.NewDomain.com -UseGMSA:$false
This example disables the gMSA and modifies the plug-in services to Domain or LocalSystem for host h1.NewDomain.com.
