SnapCenter cmdlets
Set-SmHost
Modifies either the port or the group Managed Service Account (gMSA) or the credential name of the host.
Syntax
Set-SmHost [-HostName]  <String>  [-Port]  <UInt16>  [-CredentialName]  <String>  [-UseGMSA]  <Boolean>  [-GMSAName]  <String>  [-PushServerCredentialsToSCV]  <SwitchParameter>  [-Force]  <SwitchParameter>
Detailed Description
Modifies either the port or the group Managed Service Account (gMSA) or the credential name of the host. Only one parameter can be modified at a time.
Name Description Required? Pipeline Input Default Value
HostName
The name of the host whose port or credential name will be modified.
true
true (ByPropertyName)
Port
The port to be modified.
false
CredentialName
The credential name to be modified.
false
UseGMSA
Modify the plug-in services logon from gMSA to domain or LocalSystem.
false
GMSAName
The group Managed Service Account (gMSA) name to be modified.
false
Push the credentials to the SCV host.
false
Force
false
Example 1: Modifying port from 8145 to 8185
 Set-SmHost -HostName h1 -Port 8185
This example modifies the port of host h1 to 8185.
Example 2: Modifying credential name from RunAs1 to RunAs2
 Set-SmHost -HostName h1 -CredentialName RunAs2
This example modifies the credential name of host h1 to RunAs2.
Example 3: Modifying group Managed Service Account (gMSA) name from NewDomain\gMSAName1$ to NewDomain\gMSAName2$
 Set-SmHost -HostName h1.NewDomain.com -UseGMSA:$true -GMSAName NewDomain\gMSAName2$
This example modifies the gMSA name for host h1.NewDomain.com to NewDomain\gMSAName2$.
Example 4: Disabling group Managed Service Account (gMSA)
 Set-SmHost -HostName h1.NewDomain.com -UseGMSA:$false
This example disables the gMSA and modifies the plug-in services to Domain or LocalSystem for host h1.NewDomain.com.
