SnapCenter cmdlets
Invoke-DiagnosticLogCollection
Gets SnapCenter log files.
Syntax
Invoke-DiagnosticLogCollection [-SnapCenter]  <>  [-Hosts]  <String>  [-svms]  <String>  [-vcenter]  <String>  [-joblogs]  <Int64>  [-Cluster]  <String>
Detailed Description
Gets SnapCenter log files. Log files are returned in a .zip file. You can retrieve all SnapCenter logs, Svms, Vcenter, Cluster or logs for a individual plug-in or SnapCenter instance. You can also get logs for a specified job.
Name Description Required? Pipeline Input Default Value
SnapCenter
false
true (ByPropertyName)
Hosts
false
svms
false
vcenter
false
joblogs
false
Cluster
false
Example 1: Retrieving all logs
 Invoke-DiagnosticLogCollection -SnapCenter
This example syntax retrieves all log files.
Example 2: Retrieving logs for a designated jobs
 Invoke-DiagnosticLogCollection -Joblogs 1234,1235
This example syntax retrieves logs for job ID 1234 ad 1235.
Example 3: Retrieving Cluster logs
 Invoke-DiagnosticLogCollection -Cluster host123
This example syntax retrieves all cluster node logs.
Example 4: Retrieving Hosts logs
 Invoke-DiagnosticLogCollection -Hosts hostname1,hostname2
This example syntax retrieves all the hosts server,plugin and config logs.
Example 5: Retrieving svms logs
 Invoke-DiagnosticLogCollection -svms Vserver1,Vserver2
This example syntax retrieves all the vserver logs.
