Invoke-DiagnosticLogCollection
Gets SnapCenter log files.
Syntax
Invoke-DiagnosticLogCollection [-SnapCenter] <> [-Hosts] <String> [-svms] <String> [-vcenter] <String> [-joblogs] <Int64> [-Cluster] <String>
Detailed Description
Gets SnapCenter log files. Log files are returned in a .zip file. You can retrieve all SnapCenter logs, Svms, Vcenter, Cluster or logs for a individual plug-in or SnapCenter instance. You can also get logs for a specified job.
Name | Description | Required? | Pipeline Input | Default Value |
SnapCenter |
false |
true (ByPropertyName) |
Hosts |
false |
svms |
false |
vcenter |
false |
joblogs |
false |
Cluster |
false |
Example 1: Retrieving all logs
Invoke-DiagnosticLogCollection -SnapCenter
This example syntax retrieves all log files.
Example 2: Retrieving logs for a designated jobs
Invoke-DiagnosticLogCollection -Joblogs 1234,1235
This example syntax retrieves logs for job ID 1234 ad 1235.
Example 3: Retrieving Cluster logs
Invoke-DiagnosticLogCollection -Cluster host123
This example syntax retrieves all cluster node logs.
Example 4: Retrieving Hosts logs
Invoke-DiagnosticLogCollection -Hosts hostname1,hostname2
This example syntax retrieves all the hosts server,plugin and config logs.
Example 5: Retrieving svms logs
Invoke-DiagnosticLogCollection -svms Vserver1,Vserver2
This example syntax retrieves all the vserver logs.
