Get-SmClone
Gets information about existing clones.
Syntax
Get-SmClone [-CloneName] <String> [-CloneId] <String> [-Dataset] <String> [-BackupName] <String> [-BackupId] <String> [-AppObjectName] <String> [-AppPluginCode] <PluginCode> [-ListStorageFootprint] <SwitchParameter>
Detailed Description
Gets information about existing clones. You can also search existing clones based on clone name, clone ID, application object, and backup ID.
| Name | Description | Required? | Pipeline Input | Default Value |
CloneName |
Specifies that you want informtion about a single clone. |
false |
true (ByPropertyName) |
CloneId |
Provides a clone ID for the clone about which you want information. You can get the clone ID by running Get-SmClone without any input, and then use the clone ID to retrieve more detailed information about the specified clone. |
false |
Dataset |
Retrieves information based on dataset name. |
false |
BackupName |
Retrieves information based on backup name. |
false |
BackupId |
Retrieves information based on a specified backup ID. Get the backup ID by running Get-SmBackup without parameters. |
false |
AppObjectName |
Retrieves information based on database name. |
false |
AppPluginCode |
Specifies the application plug-in type of the resource. Possible values are SCSQL and SCO. |
false |
false |
ListStorageFootprint |
List the storage footprint information such as storage resource name, type, and junction path in case of volume. This parameter is applicable to SCC plug-in. |
false |
false |
Example 1: Retrieving information about all clones
Get-SmClone
This example syntax retrieves information about all clones.
CloneName : cds__clone__06-18-2015_13.51.03
CloneStartTime : 6/18/2015 1:50:57 PM
CloneEndTime : 6/18/2015 1:51:03 PM
Databases : {SourceDB = test,CloneDB = testabcdefg}
CloneId: 4
CloneName : payrollclone_dataset__clone__08-05-2015_14.41.11
CloneStartTime : 8/5/2015 2:40:41 PM
CloneEndTime : 8/5/2015 2:41:11 PM
Databases : {SourceDB = payroll,CloneDB = payroll__clone}
Example 2: Retrieving information for a clone dataset
Get-SmClone -Dataset payrollclone_dataset
This example syntax retrieves information for the specified clone dataset.
CloneId: 4
Example 3: Retrieving clone information for a backup
Get-SmClone -BackupName cds_vise-f4_06-18-2015_13.50.52.1978
This example syntax retrieves the clone information for the specified backup.
CloneId: 3
Example 4: Getting clone information for a database
Get-SmClone -AppObjectName vise-f3\sqlexpress\payroll
This example syntax retrieves information for the specified database.
CloneId: 4
Example 5: Retrieving clone information using a backup ID
Get-SmClone -BackupId 7
This example syntax retrieves clone information using the specified backup ID.
CloneId: 4
Example 6: Retrieving clone information along with storage footprint for HANA plug-in resources
Get-SmClone -ListStorageFootprint
This example syntax retrieves clone information along with storage footprint for HANA plug-in resources.
CloneId : 38 CloneName: scspr0965644001.gdl.englab.netapp.com_hana_MDC_H14 CloneStartTime : 11/15/2019 4:15:41 AM CloneEndTime : 11/15/2019 4:19:17 AM Resources: Source = H14, Clone = H14 StorageFootPrint : StorageResourceType : SDStorageDir, StorageResource : buck.gdl.englab.netapp.com:/vol/NFS_H14_MDCMT_DATA_10_234_131_2291115190001059572, JunctionPath : /Scb461b683-f1cb-4350-a1a1-0f0d29b62d3f CloneId : 39 CloneName: scspr0965644001.gdl.englab.netapp.com_hana_H14 CloneStartTime : 11/15/2019 5:39:06 AM CloneEndTime : 11/15/2019 5:40:06 AM Resources: Source = H14, Clone = H14 StorageFootPrint : StorageResourceType : SDStorageLunPath, StorageResource : buck:/vol/SAN_H14_SC_DATA_10_234_176_1201115190121551593/SAN_H14_SC_DATA_10_234_176_120
