SnapCenter 4.8 cmdlets
Get-SmClone
Gets information about existing clones.
Syntax
Get-SmClone [-CloneName]  <String>  [-CloneId]  <String>  [-Dataset]  <String>  [-BackupName]  <String>  [-BackupId]  <String>  [-AppObjectName]  <String>  [-AppPluginCode]  <PluginCode>  [-ListStorageFootprint]  <SwitchParameter>
Detailed Description
Gets information about existing clones. You can also search existing clones based on clone name, clone ID, application object, and backup ID.
Name Description Required? Pipeline Input Default Value
CloneName
Specifies that you want informtion about a single clone.
false
true (ByPropertyName)
CloneId
Provides a clone ID for the clone about which you want information. You can get the clone ID by running Get-SmClone without any input, and then use the clone ID to retrieve more detailed information about the specified clone.
false
Dataset
Retrieves information based on dataset name.
false
BackupName
Retrieves information based on backup name.
false
BackupId
Retrieves information based on a specified backup ID. Get the backup ID by running Get-SmBackup without parameters.
false
AppObjectName
Retrieves information based on database name.
false
AppPluginCode
Specifies the application plug-in type of the resource. Possible values are SCSQL and SCO.
false
false
List the storage footprint information such as storage resource name, type, and junction path in case of volume. This parameter is applicable to SCC plug-in.
false
false
Example 1: Retrieving information about all clones
 Get-SmClone
This example syntax retrieves information about all clones.
CloneName  : cds__clone__06-18-2015_13.51.03
CloneStartTime : 6/18/2015 1:50:57 PM
CloneEndTime   : 6/18/2015 1:51:03 PM
Databases  : {SourceDB = test,CloneDB = testabcdefg}
CloneId: 4
CloneName  : payrollclone_dataset__clone__08-05-2015_14.41.11
CloneStartTime : 8/5/2015 2:40:41 PM
CloneEndTime   : 8/5/2015 2:41:11 PM
Databases  : {SourceDB = payroll,CloneDB = payroll__clone}
Example 2: Retrieving information for a clone dataset
 Get-SmClone -Dataset payrollclone_dataset
This example syntax retrieves information for the specified clone dataset.
CloneId: 4
Example 3: Retrieving clone information for a backup
 Get-SmClone -BackupName cds_vise-f4_06-18-2015_13.50.52.1978
This example syntax retrieves the clone information for the specified backup.
CloneId: 3
Example 4: Getting clone information for a database
 Get-SmClone -AppObjectName vise-f3\sqlexpress\payroll
This example syntax retrieves information for the specified database.
CloneId: 4
Example 5: Retrieving clone information using a backup ID
 Get-SmClone -BackupId 7
This example syntax retrieves clone information using the specified backup ID.
CloneId: 4
Example 6: Retrieving clone information along with storage footprint for hana plug-in resources
 Get-SmClone -ListStorageFootprint
This example syntax retrieves clone information along with storage footprint for hana plug-in resources.
CloneId  : 38
CloneName: scspr0965644001.gdl.englab.netapp.com_hana_MDC_H14
CloneStartTime   : 11/15/2019 4:15:41 AM
CloneEndTime : 11/15/2019 4:19:17 AM
Resources: Source = H14, Clone = H14
StorageFootPrint : StorageResourceType : SDStorageDir, StorageResource : buck.gdl.englab.netapp.com:/vol/NFS_H14_MDCMT_DATA_10_234_131_2291115190001059572, JunctionPath : /Scb461b683-f1cb-4350-a1a1-0f0d29b62d3f
CloneId  : 39
CloneName: scspr0965644001.gdl.englab.netapp.com_hana_H14
CloneStartTime   : 11/15/2019 5:39:06 AM
CloneEndTime : 11/15/2019 5:40:06 AM
StorageFootPrint : StorageResourceType : SDStorageLunPath, StorageResource : buck:/vol/SAN_H14_SC_DATA_10_234_176_1201115190121551593/SAN_H14_SC_DATA_10_234_176_120
