Set-SdVsphereSetting
Sets your vSphere user credentials, if vSphere is enabled.
Syntax
Set-SdVsphereSetting [-VsphereOrEsxHost] <String> [-Credential] <PSCredential> [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
VsphereOrEsxHost |
Specifies your vSphere or ESX host, on which you want to set your vSphere credentials. |
true |
true (ByValue, ByPropertyName) |
Credential |
Specifies the user name and password you want to use to access vSphere. |
true |
true (ByPropertyName) |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
