SnapCenter cmdlets
Set-SdVsphereSetting
Sets your vSphere user credentials, if vSphere is enabled.
Syntax
Set-SdVsphereSetting [-VsphereOrEsxHost]  <String>  [-Credential]  <PSCredential>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
VsphereOrEsxHost
Specifies your vSphere or ESX host, on which you want to set your vSphere credentials.
true
true (ByValue, ByPropertyName)
Credential
Specifies the user name and password you want to use to access vSphere.
true
true (ByPropertyName)
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
