      Set-SdVsphereSetting
Sets your vSphere user credentials, if vSphere is enabled.
Syntax
Set-SdVsphereSetting [-VsphereOrEsxHost] <String> [-Credential] <PSCredential> [-Session] <String> [-Host] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
| VsphereOrEsxHost | Specifies your vSphere or ESX host, on which you want to set your vSphere credentials. | true | true (ByValue, ByPropertyName) | |
| Credential | Specifies the user name and password you want to use to access vSphere. | true | true (ByPropertyName) | |
| Session | false | true (ByPropertyName) | ||
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) |
 PDFs
PDFs
