Remove-SmServerCluster
Removes the High Availability cluster configuration on the SnapCenter Server
Syntax
Remove-SmServerCluster [-Credential] <PSCredential> [-ClusterNameString] <String> [-ClusterIPString] <String>
Detailed Description
Removes the High Availability cluster configuration on the SnapCenter Server. This can be used to convert to Standalone configuration.
| Name | Description | Required? | Pipeline Input | Default Value |
| Credential | Provides domain user credentials for the user to remove High Availability cluster configuration. | true | true (ByPropertyName) | |
| ClusterName | F5 cluster name. | false | false | |
| ClusterIP | F5 Cluster IP Address. | true | false |
Example 1: Removing High Availability cluster configuration on the SnapCenter Server
Remove-SmServerCluster -Credential sddev\administrator -ClusterIP 10.235.236.190 -ClusterName f5pool
This removes the High Availability cluster configuration on the SnapCenter Server.
Name: Remove High Availability for SnapCenter Server
StartTime   : 10/5/2019 6:19:26 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
Monitor the progress of job 972 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 972'
 PDFs
PDFs
