SnapCenter 4.8 cmdlets
Remove-SmServerCluster
Removes the High Availability cluster configuration on the SnapCenter Server
Syntax
Remove-SmServerCluster [-Credential]  <PSCredential>  [-ClusterNameString]  <String>  [-ClusterIPString]  <String>
Detailed Description
Removes the High Availability cluster configuration on the SnapCenter Server. This can be used to convert to Standalone configuration.
Name Description Required? Pipeline Input Default Value
Credential
Provides domain user credentials for the user to remove High Availability cluster configuration.
true
true (ByPropertyName)
ClusterName
F5 cluster name.
false
false
ClusterIP
F5 Cluster IP Address.
true
false
Example 1: Removing High Availability cluster configuration on the SnapCenter Server
 Remove-SmServerCluster -Credential sddev\administrator -ClusterIP 10.235.236.190 -ClusterName f5pool
This removes the High Availability cluster configuration on the SnapCenter Server.
Name: Remove High Availability for SnapCenter Server
StartTime   : 10/5/2019 6:19:26 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
Monitor the progress of job 972 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 972'
