Remove-SmServerCluster
Removes the High Availability cluster configuration on the SnapCenter Server
Syntax
Remove-SmServerCluster [-Credential] <PSCredential> [-ClusterNameString] <String> [-ClusterIPString] <String>
Detailed Description
Removes the High Availability cluster configuration on the SnapCenter Server. This can be used to convert to Standalone configuration.
| Name | Description | Required? | Pipeline Input | Default Value |
Credential |
Provides domain user credentials for the user to remove High Availability cluster configuration. |
true |
true (ByPropertyName) |
ClusterName |
F5 cluster name. |
false |
false |
ClusterIP |
F5 Cluster IP Address. |
true |
false |
Example 1: Removing High Availability cluster configuration on the SnapCenter Server
Remove-SmServerCluster -Credential sddev\administrator -ClusterIP 10.235.236.190 -ClusterName f5pool
This removes the High Availability cluster configuration on the SnapCenter Server.
Name: Remove High Availability for SnapCenter Server
StartTime : 10/5/2019 6:19:26 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
Monitor the progress of job 972 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 972'
