New-SmMountBackup
Initiates a mount operation for a given backup.
Syntax
New-SmMountBackup [-BackupName] <String> [-HostName] <String> [-AppObjectId] <String> [-ArchivedLocators] <Hashtable[]> [-AsmCredentialName] <String> [-AsmPort] <Int32>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
BackupName |
Specifies the name of the backup being mounted. |
true |
true (ByPropertyName) |
HostName |
Specifies the name of the host on which you want to mount the backup. |
true |
AppObjectId |
Specifies the application object name and type. For example: -AppObjectId "linux.serengeti.com\orcl" |
true |
ArchivedLocators |
Specifies in a hash table, the primary and secondary storage system and volume locations. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"} |
false |
AsmCredentialName |
false |
false |
AsmPort |
Specifies the port on which the Oracle ASM instance is available. |
false |
false |
Example 1: Mounting a backup
New-SmMountBackup –BackupName dailyset1_linux_10-12-2015_18.19.07.1866_0 -HostName linux.serengeti.com -AppObjectId "linux.serengeti.com\orcl"
This example syntax mounts an Oracle backup.
Example 2: Mounting an ASM database backup using a Run As account and port
New-SmMountBackup -BackupName "dbMigSrcAsm_Dataset_scspr0070373002_12-14-2015_09.56.41.
7460_0" -HostName "scspr0070373002.gdl.netapp.com" -AppObjectId "scspr0070373002.gdl.netapp.com\dbMigSrcA
sm" -ASMRunAsName "mounter" -ASMPort 1521
This example syntax mounts an ASM database backup using the specified ASM Run As account and port.
Mount started successfully
Name: Mount Backup dbMigSrcAsm_Dataset_scspr0070373002_12-14-2015_09.56.41.7460_0
StartTime : 12/14/2015 10:01:43 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : False
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 3: Mounting a backup using archived locators
New-SmMountBackup –BackupName dailyset1_linux_10-12-2015_18.19.07.1866_0 -HostName linux.serengeti.com -AppObjectId "linux.serengeti.com\orcl" -ArchivedLocators @{Primary="test_vs1:test1_vol";Secondary=
"test_vs1:test1_vol_SECONDARY"}
This example syntax mounts a backup using archived locators.
