SnapCenter cmdlets
New-SmMountBackup
Initiates a mount operation for a given backup.
Syntax
New-SmMountBackup [-BackupName]  <String>  [-HostName]  <String>  [-AppObjectId]  <String>  [-ArchivedLocators]  <Hashtable[]>  [-AsmCredentialName]  <String>  [-AsmPort]  <Int32>
Detailed Description
Name Description Required? Pipeline Input Default Value
BackupName
Specifies the name of the backup being mounted.
true
true (ByPropertyName)
HostName
Specifies the name of the host on which you want to mount the backup.
true
AppObjectId
Specifies the application object name and type. For example: -AppObjectId "linux.serengeti.com\orcl"
true
ArchivedLocators
Specifies in a hash table, the primary and secondary storage system and volume locations. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"}
false
AsmCredentialName
false
false
AsmPort
Specifies the port on which the Oracle ASM instance is available.
false
false
Example 1: Mounting a backup
 New-SmMountBackup –BackupName dailyset1_linux_10-12-2015_18.19.07.1866_0 -HostName linux.serengeti.com  -AppObjectId "linux.serengeti.com\orcl"
This example syntax mounts an Oracle backup.
Example 2: Mounting an ASM database backup using a Run As account and port
 New-SmMountBackup -BackupName "dbMigSrcAsm_Dataset_scspr0070373002_12-14-2015_09.56.41.
          7460_0" -HostName "scspr0070373002.gdl.netapp.com" -AppObjectId "scspr0070373002.gdl.netapp.com\dbMigSrcA
          sm" -ASMRunAsName "mounter" -ASMPort 1521
This example syntax mounts an ASM database backup using the specified ASM Run As account and port.
Mount started successfully
Name: Mount Backup dbMigSrcAsm_Dataset_scspr0070373002_12-14-2015_09.56.41.7460_0
StartTime   : 12/14/2015 10:01:43 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : False
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
Example 3: Mounting a backup using archived locators
 New-SmMountBackup –BackupName dailyset1_linux_10-12-2015_18.19.07.1866_0 -HostName linux.serengeti.com  -AppObjectId "linux.serengeti.com\orcl" -ArchivedLocators @{Primary="test_vs1:test1_vol";Secondary=
          "test_vs1:test1_vol_SECONDARY"}
This example syntax mounts a backup using archived locators.
