Remove-SmResourceDRMode
Remove resources from disaster recovery mode.
Syntax
Remove-SmResourceDRMode [-HostNames] <> [-AppObjectIds] <>
Detailed Description
Remove the resources from disaster recovery mode.
| Name | Description | Required? | Pipeline Input | Default Value |
HostNames |
Specifies one or more hosts (FQDN) to remove all the resources of the hosts from disaster recovery mode. |
true |
true (ByPropertyName) |
AppObjectIds |
Specifies one or more application object identifier of an SQL database to remove from disaster recovery mode. |
true |
Example 1: Removing all resources of the host from disaster recovery mode
Remove-SmResourceDRMode -HostNames host1.gdl.netapp.com
This example syntax removes all the resources of the host from disaster recovery mode.
Result : SMCoreContracts.SMResult TotalCount : 0 DisplayCount : 0 Context : Job : SMCoreContracts.SmJob
Example 2: Removing all resources of multiple hosts from disaster recovery mode
Remove-SmResourceDRMode -HostNames host1.gdl.netapp.com,host2.gdl.netapp.com
This example syntax removes all the resources of hosts from disaster recovery mode.
Example 3: Removing all resources of the cluster host from disaster recovery mode
Remove-SmResourceDRMode -HostNames Clusterhost.netapp.com,Node1.netapp.com,Node2.netapp.com
This example syntax removes all the resources of cluster host from disaster recovery mode. Specify cluster host with all the nodes.
Example 4: Removing SQL resource from disaster recovery mode
Remove-SmResourceDRMode -AppObjectIds Host1/Inst1/DB1
This example syntax removes SQL resource from disaster recovery mode.
Example 5: Removing multiple SQL resources from disaster recovery mode
Remove-SmResourceDRMode -AppObjectIds Host1/Inst1/DB1,Host1/Inst1/DB2
This example syntax removes SQL resources from disaster recovery mode.
