SnapCenter 4.8 cmdlets
Remove-SmResourceDRMode
Remove resources from disaster recovery mode.
Syntax
Remove-SmResourceDRMode [-HostNames]  <>  [-AppObjectIds]  <>
Detailed Description
Remove the resources from disaster recovery mode.
Name Description Required? Pipeline Input Default Value
HostNames
Specifies one or more hosts (FQDN) to remove all the resources of the hosts from disaster recovery mode.
true
true (ByPropertyName)
AppObjectIds
Specifies one or more application object identifier of an SQL database to remove from disaster recovery mode.
true
Example 1: Removing all resources of the host from disaster recovery mode
 Remove-SmResourceDRMode -HostNames host1.gdl.netapp.com
This example syntax removes all the resources of the host from disaster recovery mode.
			Result   : SMCoreContracts.SMResult
			TotalCount   : 0
			DisplayCount : 0
			Context  :
			Job  : SMCoreContracts.SmJob
Example 2: Removing all resources of multiple hosts from disaster recovery mode
 Remove-SmResourceDRMode -HostNames host1.gdl.netapp.com,host2.gdl.netapp.com
This example syntax removes all the resources of hosts from disaster recovery mode.
			TotalCount   : 0
			DisplayCount : 0
			Context  :
Example 3: Removing all resources of the cluster host from disaster recovery mode
 Remove-SmResourceDRMode -HostNames Clusterhost.netapp.com,Node1.netapp.com,Node2.netapp.com
This example syntax removes all the resources of cluster host from disaster recovery mode. Specify cluster host with all the nodes.
			TotalCount   : 0
			DisplayCount : 0
			Context  :
Example 4: Removing SQL resource from disaster recovery mode
 Remove-SmResourceDRMode -AppObjectIds Host1/Inst1/DB1
This example syntax removes SQL resource from disaster recovery mode.
			TotalCount   : 0
			DisplayCount : 0
			Context  :
Example 5: Removing multiple SQL resources from disaster recovery mode
 Remove-SmResourceDRMode -AppObjectIds Host1/Inst1/DB1,Host1/Inst1/DB2
This example syntax removes SQL resources from disaster recovery mode.
			TotalCount   : 0
			DisplayCount : 0
			Context  :
