SnapCenter cmdlets
Remove-SdSnapMirrorPolicyRule
Removes the rules from the SnapMirror policy associated with the SnapVault relationship.
Syntax
Remove-SdSnapMirrorPolicyRule [-SourceStorageSystem]  <String>  [-SourceStorageSystemVolume]  <String>  [-DestinationStorageSystem]  <String>  [-DestinationStorageSystemVolume]  <String>  [-SnapMirrorLabel]  <String[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Removes the rules from the SnapMirror policy associated with the SnapVault relationship. Related cmdlets: Set-SdSnapMirrorPolicyRule, Get-SdSnapMirrorPolicyRule
Name Description Required? Pipeline Input Default Value
SourceStorageSystem
Specifies the primary storage system name containing the source volumes of the SnapMirror relationship for which you want to remove the SnapMirror policy rules. IP addresses are not supported.
true
true (ByValue, ByPropertyName)
Specifies the source volume of the SnapMirror relationship for which you want to remove the SnapMirror policy rules.
true
true (ByPropertyName)
Specifies the secondary storage system name containing the destination volumes of the SnapMirror relationship for which you want to remove the SnapMirror policy rules. IP addresses are not supported.
true
Specifies the destination volume of the SnapMirror relationship for which you want to remove the SnapMirror policy rules.
true
SnapMirrorLabel
Specifies the SnapMirror policy rule which you want to remove.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Removing SnapMirror policy rule information from the policy for a SnapMirror relationship
 PS C:\> Remove-SdSnapMirrorPolicyRule -SourceStorageSystem vs01 -SourceStorageSystemVolume src_vol01 -DestinationStorageSystem vs02 -DestinationStorageSystemVolume dest_vol01 -SnapMirrorLabel myWeekly,myMonthly -verbose -Confirm:$false
Removes the SnapMirror policy rules (myWeekly, myMonthly) from the policy on the specified relationship.
