Set-SmSchedule
Creates a schedule using information you provide and also trigger schedule based on info.
Syntax
Set-SmSchedule [-ScheduleInformation] <Hashtable> [-TaskName] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
ScheduleInformation |
Specifies mandatory schedule information in a hashtable. |
true |
true (ByPropertyName) |
TaskName |
Specifies the mandatory task name.Supported Task : SnapCenterDataCollection, SnapCenterJobsRetention, SnapCenter_AlertCleanUp, SnapCenter_StaleJobCleanUp, SnapCenter_RefreshSyncSnapMirrorBackups,SnapCenter_AuditDiskSpaceCheck, SnapCenter_RemoveSecondaryBackup, SnapCenter_RefreshBackupSnapLock, SnapCenter_ComputeStorageSavings |
true |
Example 1: Setting a Hourly schedule for any maintainenace task
Set-SmSchedule -ScheduleInformation @{"ScheduleType"="Hourly";"StartTime"="10:10 AM" ;"EndTime"="11:00 AM";"RepeatTask_Every_Hour"="00:15"} -TaskName SnapCenter_RemoveSecondaryBackup
This example syntax creates an hourly schedule with the task name SnapCenter_RemoveSecondaryBackup that repeats every 15 minutes.
TaskName : SnapCenter_RemoveSecondaryBackup
Hosts : {}
StartTime : 5/14/2017 10:10:00 AM
DaysoftheMonth:
MonthsofTheYear :
DaysInterval :
DaysOfTheWeek :
AllowDefaults : False
ReplaceJobIfExist : False
UserName :
Password :
SchedulerType : Hourly
RepeatTask_Every_Hour : 0
IntervalDuration :
EndTime : 5/14/2017 11:00:00 AM
LocalScheduler: False
AppType : False
AuthMode :
SchedulerSQLInstance : SMCoreContracts.SmObject
MonthlyFrequency :
Hour : 0
Minute: 0
NodeName :
ScheduleID: 0
RepeatTask_Every_Mins : 15
Example 2 : Setting a Daily schedule for any maintenance task
Set-SmSchedule -ScheduleInformation @{"ScheduleType"="Daily";"StartTime"="02:45 AM";"DaysInterval"="1"} -TaskName SnapCenter_AuditIntegrityCheck
This example syntax creates an daily schedule with the task name SnapCenter_AuditIntegrityCheck that repeats daily at mentioned start time.
TaskName : SnapCenter_AuditIntegrityCheck
Hosts : {}
StartTime : 8/20/2025 2:45:00 AM
DaysoftheMonth:
MonthsofTheYear :
DaysInterval : 1
DaysOfTheWeek :
UserName :
Password :
SchedulerType : Daily
Example 3 : Setting a Weekly schedule for any maintenance task
Set-SmSchedule -ScheduleInformation @{"ScheduleType"="Weekly";"StartTime"="02:36 AM";"DaysOfTheWeek"="Wednesday"} -TaskName SnapCenter_ComputeStorageSavings
This example syntax creates an daily schedule with the task name SnapCenter_ComputeStorageSavings that repeats Weekly at provided start time on provided days of the week.
TaskName : SnapCenter_ComputeStorageSavings
Hosts : {}
StartTime : 8/20/2025 2:36:00 AM
DaysoftheMonth:
MonthsofTheYear :
DaysInterval :
DaysOfTheWeek : Wednesday
UserName :
Password :
SchedulerType : Weekly
RepeatTask_Every_Hour : 1
IntervalDuration :
EndTime :
AppType : False
AuthMode :
Example 4 : Setting a Monthly schedule for any maintenance task
Set-SmSchedule -ScheduleInformation @{"ScheduleType"="Monthly";"StartTime"="06:45 AM";"DaysoftheMonth"="20";""MonthsOfTheYear"="AUGUST"} -TaskName SnapCenter_AuditIntegrityCheck
This example syntax creates an daily schedule with the task name SnapCenter_AuditIntegrityCheck that repeats monthly at provided start time on provided days of the month.
Hosts : {}
StartTime : 8/20/2025 6:45:00 AM
DaysoftheMonth: 20
MonthsofTheYear : AUGUST
DaysInterval :
DaysOfTheWeek :
UserName :
Password :
SchedulerType : Monthly
IntervalDuration :
EndTime :
AppType : False
AuthMode :
