Set-SmSchedule
Creates a schedule using information you provide and also cleans up secondary backups according to that schedule.
Syntax
Set-SmSchedule [-ScheduleInformation] <Hashtable> [-TaskName] <String>
Detailed Description
| Name | Description | Required? | Pipeline Input | Default Value |
ScheduleInformation |
Specifies mandatory schedule information in a hashtable. |
true |
true (ByPropertyName) |
TaskName |
Specifies the mandatory task name. |
true |
Example 1: Setting a schedule to remove secondary backups
Set-SmSchedule -ScheduleInformation @{"ScheduleType"="Hourly";"StartTime"="10:10 AM" ;"EndTime"="11:00 AM";"RepeatTask_Every_Hour"="00:15"} -TaskName SnapCenter_RemoveSecondaryBackup
This example syntax creates an hourly schedule with the task name SnapCenter_RemoveSecondaryBackup that repeats every 15 minutes.
TaskName : SnapCenter_RemoveSecondaryBackup
Hosts : {}
StartTime : 5/14/2017 10:10:00 AM
DaysoftheMonth:
MonthsofTheYear :
DaysInterval :
DaysOfTheWeek :
AllowDefaults : False
ReplaceJobIfExist : False
UserName :
Password :
SchedulerType : Hourly
RepeatTask_Every_Hour : 0
IntervalDuration :
EndTime : 5/14/2017 11:00:00 AM
LocalScheduler: False
AppType : False
AuthMode :
SchedulerSQLInstance : SMCoreContracts.SmObject
MonthlyFrequency :
Hour : 0
Minute: 0
NodeName :
ScheduleID: 0
RepeatTask_Every_Mins : 15
