SnapCenter 4.7 cmdlets
Set-SmSchedule
Creates a schedule using information you provide and also cleans up secondary backups according to that schedule.
Syntax
Set-SmSchedule [-ScheduleInformation]  <Hashtable>  [-TaskName]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
ScheduleInformation
Specifies mandatory schedule information in a hashtable.
true
true (ByPropertyName)
TaskName
Specifies the mandatory task name.
true
Example 1: Setting a schedule to remove secondary backups
 Set-SmSchedule -ScheduleInformation @{"ScheduleType"="Hourly";"StartTime"="10:10 AM" ;"EndTime"="11:00 AM";"RepeatTask_Every_Hour"="00:15"} -TaskName SnapCenter_RemoveSecondaryBackup
This example syntax creates an hourly schedule with the task name SnapCenter_RemoveSecondaryBackup that repeats every 15 minutes.
TaskName  : SnapCenter_RemoveSecondaryBackup
Hosts : {}
StartTime : 5/14/2017 10:10:00 AM
DaysoftheMonth:
MonthsofTheYear   :
DaysInterval  :
DaysOfTheWeek :
AllowDefaults : False
ReplaceJobIfExist : False
UserName  :
Password  :
SchedulerType : Hourly
RepeatTask_Every_Hour : 0
IntervalDuration  :
EndTime   : 5/14/2017 11:00:00 AM
LocalScheduler: False
AppType   : False
AuthMode  :
SchedulerSQLInstance  : SMCoreContracts.SmObject
MonthlyFrequency  :
Hour  : 0
Minute: 0
NodeName  :
ScheduleID: 0
RepeatTask_Every_Mins : 15
