Update-SmServerCluster
Updates the High Availability cluster configuration on the SnapCenter Server
Syntax
Update-SmServerCluster [-Credential] <PSCredential> [-ClusterNameString] <String> [-ClusterIPString] <String>
Detailed Description
Updates the High Availability cluster configuration on the SnapCenter Server. This can be used to update the cluster name or cluster IP Address.
| Name | Description | Required? | Pipeline Input | Default Value |
Credential |
Provides domain user credentials for the user to update High Availability cluster configuration. |
true |
true (ByPropertyName) |
ClusterName |
F5 cluster name. |
false |
false |
ClusterIP |
F5 Cluster IP Address. |
true |
false |
Example 1: Updates High Availability cluster configuration on the SnapCenter Server
Update-SmServerCluster -Credential sddev\administrator -ClusterName Sab_Pool_Update -ClusterIP 10.225.231.160
This example updates the High Availability cluster configuration on the SnapCenter Server.
Name: Modify High Availability for SnapCenter Server Configuration
StartTime : 10/7/2019 3:31:55 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Running
Owner :
Error :
Priority: None
Tasks : {Update HA Parameters in SC Repository}
ParentJobID : 0
EventId : 0
JobTypeId : 38
ApisJobKey :
ObjectId: 0
PluginCode : NONE
PluginName : NONE
HostId : 0
RoleId :
JobIds : {}
Monitor the progress of job 59 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 59'
