SnapCenter 4.8 cmdlets
Update-SmServerCluster
Updates the High Availability cluster configuration on the SnapCenter Server
Syntax
Update-SmServerCluster [-Credential]  <PSCredential>  [-ClusterNameString]  <String>  [-ClusterIPString]  <String>
Detailed Description
Updates the High Availability cluster configuration on the SnapCenter Server. This can be used to update the cluster name or cluster IP Address.
Name Description Required? Pipeline Input Default Value
Credential
Provides domain user credentials for the user to update High Availability cluster configuration.
true
true (ByPropertyName)
ClusterName
F5 cluster name.
false
false
ClusterIP
F5 Cluster IP Address.
true
false
Example 1: Updates High Availability cluster configuration on the SnapCenter Server
 Update-SmServerCluster -Credential sddev\administrator -ClusterName Sab_Pool_Update -ClusterIP 10.225.231.160
This example updates the High Availability cluster configuration on the SnapCenter Server.
Name: Modify High Availability for SnapCenter Server Configuration
StartTime   : 10/7/2019 3:31:55 AM
EndTime :
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Running
Owner   :
Error   :
Priority: None
Tasks   : {Update HA Parameters in SC Repository}
ParentJobID : 0
EventId : 0
JobTypeId   : 38
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  : NONE
HostId  : 0
RoleId  :
JobIds  : {}
Monitor the progress of job 59 in the Job Monitor page or by running the cmdlet: 'Get-SmJobSummaryReport -JobId 59'
