SnapCenter 4.7 cmdlets
Remove-SmStorageConnection
Removes a storage system connection.
Syntax
Remove-SmStorageConnection [-Storage]  <String>  [-AzureNetAppAccountIds]  <bigint(20)>
Detailed Description
Removes a storage system connection. You can remove one storage system connection at a time.
Name Description Required? Pipeline Input Default Value
Storage
false
true (ByPropertyName)
Example 1: Removing a storage system connection
 Remove-SmStorageConnection -SVM 172.17.168.13
This example syntax removes a storage system connection
Are you sure you want to remove the storage connection?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Remove Storage connection successful
Example 2: Removing a storage system connection without confirmation dialogue
 Remove-SmStorageConnection -SVM 172.17.168.13 -Confirm:$false
Example 3: Removing Azure NetApp Account
 Remove-SmStorageconnection -AzureNetAppAccountIds 1
This example removes Azure NetApp Accounts with specified Azure NetApp Account IDs.
